10.12.2015, 10:10 | #441 | |||
Das Auto - skoda yeti
Пользователь сказал cпасибо: | judasfan (10.12.2015) |
10.12.2015, 11:27 | #442 | |||
Автомеханик
10.12.2015, 11:31 | #443 | |||
Das Auto - Skoda YETI 1.8 TSI 6M 4x4
Если я правильно понял tomino55555 успел кодировать моторник, так что замена ABS может поможет?!
@tomino55555 Did you manage to code your motor ECU for ACC? Последний раз редактировалось judasfan; 10.12.2015 в 11:47. |
10.12.2015, 14:14 | #444 | |||
Das Auto - vw golf vi gtd 2010
@tomino55555
Did you manage to code your motor ECU for ACC?[/QUOTE] Yes, the ECU is encoded for ACC Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb Part No SW: 03L 906018 AT HW: 03L 907 309 R Component: 2.0L R4 EDC H21 7266 Coding: 001D0012047400080000 |
10.12.2015, 21:49 | #445 | |||
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb Part No SW: 03L 906018 AT HW: 03L 907 309 R Component: 2.0L R4 EDC H21 7266 Coding: 001D0012047400080000[/QUOTE] __________________________________________________ _______________ @tomino55555 After coding of motor ECU for ACC, did you check the groups to see if ACC values are present? |
10.12.2015, 21:52 | #446 | ||||
@tomino55555 After coding of motor ECU for ACC, did you check the groups to see if ACC values are present?[/QUOTE] You know what groups are they? Thank you |
10.12.2015, 22:39 | #447 | |||
tomino55555, How is fault codes in ecu engine?
Автомеханик
10.12.2015, 22:41 | #448 | |||
Part No SW: 03L 906 018 AT HW: 03L 907 309 R Component: R4 2,0L EDC H21 7266 Revision: 42H21--- Serial number: 00000000000000 Coding: 001D0012047400080000 Shop #: WSC 12345 123 999999 ASAM Dataset: EV_ECM20TDI01103L906018AT 003010 ROD: EV_ECM20TDI01103L906018AT_VW36.rod VCID: 7CF7127BF71EBCF87C3 1 Fault Found: 4332 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [167] - - MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 67906 km Date: 2022.14.10 Time: 13:41:48 Readiness: 0 0 0 0 1 |
Пользователь сказал cпасибо: | y-u-r-a (10.12.2015) |
10.12.2015, 22:44 | #449 | |||
judasfan, Данаил, ни чего не закодировал томино, такая ошибка у всех здесь...
Автомеханик
10.12.2015, 23:01 | #450 | ||||
@tomino5555 We think that your ECU doesn't support ACC! If your ECU supported ACC, you should see things like sergey83, see post #136! http://vw-golfclub.ru/forum/attachme...1&d=1403450746 |
2 пользователя(ей) сказали cпасибо: | tomino55555 (10.12.2015), y-u-r-a (10.12.2015) |
10.12.2015, 23:32 | #451 | ||||
TOMORROW check these channels I think that the unit supports it I have CFFB and the motor is fitted to the Passat B7 also |
11.12.2015, 07:30 | #452 | |||
maybe try
Coding: 001D0012045400080000 without front assist |
11.12.2015, 10:30 | #453 | ||||
General believe is that when a car, or a brand isn't suppose to have ACC, motor ECU doesn't accept the code! In rare cases it isn't true! |
12.12.2015, 15:53 | #454 | ||||
Today I try to find a channel for ACC I found only this I do not know what these values My unit supports ACC ??? thank you |
12.12.2015, 20:37 | #455 | |||
and this is without ACC
13.12.2015, 14:33 | #456 | |||
13.12.2015, 14:57 | #457 | ||||
I disconnected the ACC unit and I changed the coding the ECU 001D0012043400080000 Последний раз редактировалось tomino55555; 13.12.2015 в 15:01. |
14.12.2015, 02:54 | #458 | |||
Das Auto - VW Touran
Hi Guys! I'm Sitll trying... but not sucessed.
First of all, I Upgraded my ABS Unit to 379BS. I'm not sure If this is Important for ACC or not, but after Upgrade I don't have any more Error from Front Assist Radar (J428), because this ABS see my Radar. If I disconnet my Radar and the ABS still "coding": And those Bit's are on Byte 17 (Bit 5 , 6 and 7) funtion???? On my Engine UNIT I have this Values: And my ACC Radar see all anothers ECU's: If I disconnet my Radar, The Automatic gearbox (DSG) give me this error: And on my Steering Wheel Unit (#16) I have this Values: I don't know more What I can do, but I'm still trying! Here my AutoScan: Monday,14,December,2015,00:02:33:29653 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64 VCDS Version: 15.7.2.0 (x64) Data version: 20151124 www.Ross-Tech.com Workshop Code: 123 12345 012345 VIN: WVGZZZ1TZBxxxxxxx License Plate: Mileage: 188530km-117147mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1T (7N0) Scan: 01 02 03 08 09 10 13 15 16 17 18 19 25 2E 37 3C 42 44 46 4F 52 55 56 61 62 65 69 72 77 A5 VIN: WVGZZZ1TZBxxxxxx Mileage: 188530km-117147miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 69-Trailer -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Sporadic communication error 1000 A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFJA) Labels: 03L-906-018-CFF.clb Part No SW: 03L 906 018 D HW: 03L 907 309 R Component: R4 2,0L EDC H23 7820 Revision: 42H23--- Serial number: 00000000000000 Coding: 001D001A047400080000 Shop #: WSC 05311 000 12345 ASAM Dataset: EV_ECM20TDI01103L906018D 003004 ROD: EV_ECM20TDI01103L906018D.rod VCID: 2B5356EC4276E566EE-807E 1 Fault Found: 4332 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [167] - - MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 188517 km Date: 2015.12.12 Time: 21:33:30 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 054 H HW: 02E 927 770 AL Component: GSG DSG AG6 511 2601 Revision: 05351112 Serial number: 00001012180935 Coding: 0000020 Shop #: WSC 01324 020 00200 VCID: 1B33862CDAD615E69E-804E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS Component: ESP MK60EC1 H46 0166 Revision: 00H46001 Coding: 323B601609280E014C0D06E59022704281EB5080 Shop #: WSC 12345 123 12345 VCID: 0401DD508768CA1E4F-8050 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 3AA 907 044 BS HW: 3AA 907 044 BS Component: Climatronic H05 0606 Revision: 00001K02 Coding: 001810C002 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_Climatronic A01010 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 020DDB48957CC42E7D-8056 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 5K0 937 087 M HW: 5K0 937 087 M Component: BCM PQ35 H 011 0046 Revision: BE011001 Coding: 46180A3BC86D33E040880080740011E445DD9008636DA520E4 8062200048 Shop #: WSC 01324 020 00200 VCID: 3F8B12BCAE0E69C652-806A Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer 17121 26 0512 Coding: 009795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 150111 05 54 0403 Coding: 0730ED Subsystem 3 - Part No: 7N0 951 171 Component: DWA-Sensor 00 002 0205 Coding: 000000 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb Part No SW: 3AA 919 475 D HW: 3AA 919 475 A Component: PARKHILFE PLA H04 0007 Revision: -------- Serial number: 20441036402318 Coding: 318101 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_EPHVA2C000000000 001006 ROD: EV_EPHVA2C000000000_SE36.rod VCID: 3C7165B0B71872DE77-8068 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 3AA 907 567 A HW: 3AA 907 567 Component: AC201 RDW A 036 0170 Revision: 00036000 Serial number: 00000000579863 Coding: 0010000 Shop #: WSC 05311 000 08193 VCID: 387979A04B205EFE93-806C 2 Faults Found: 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 205 Mileage: 188534 km Time Indication: 0 Date: 2015.12.13 Time: 23:45:31 Freeze Frame: Count: 4 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 3 Reset counter: 245 Mileage: 188534 km Time Indication: 0 Date: 2015.12.13 Time: 23:47:12 Freeze Frame: Count: 15 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1T0-909-605.lbl Part No SW: 1T0 909 605 E HW: 1T0 909 605 E Component: 02 AIRBAG VW8 022 0100 Revision: 02022000 Serial number: 003K4D01XE57 Coding: 0012338 Shop #: WSC 01324 020 00200 VCID: 377B7A9C463E51869A-8062 Subsystem 1 - Serial number: 6332QSME387C4220D Subsystem 2 - Serial number: 6342QSME397E121ER Subsystem 3 - Serial number: 6352QSME307D0C20E Subsystem 4 - Serial number: 6362QSME307D4F30N No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H Component: LENKS.MODUL 009 0136 Revision: FF010039 Serial number: 20110120300946 Coding: 399AA40000 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 7CF1A5B0F798B2DE37-8028 Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H06 0010 Coding: 830000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 1T0 920 885 N HW: 1T0 920 885 N Component: KOMBI H03 0705 Serial number: 00000000000000 Coding: 181F00 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 43831E4CCAE60D2636-8016 1 Fault Found: 13654544 - Databus U1121 00 [008] - Missing Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 8 Reset counter: 245 Mileage: 188343 km Date: 2015.12.12 Time: 08:57:02 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: 1K0-815-071.clb Part No: 7N0 963 271 A Component: Zuheizer 051 2630 Revision: 00051000 Serial number: 09022126000000 Coding: 0000011 Shop #: WSC 01324 020 00200 VCID: 326D4B88AD5CB4AEAD-8066 1 Fault Found: 01444 - Under-Voltage Shut-Off (Automatic) 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 11 Reset counter: 238 Mileage: 186770 km Time Indication: 0 Date: 2015.12.04 Time: 10:00:49 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN Component: J533 Gateway H56 1642 Revision: H56 Serial number: 211013F1000993 Coding: 358002 Shop #: WSC 01324 020 00200 VCID: 7CF1A5B0FF98B2DE37-8028 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 116 Reset counter: 245 Mileage: 188343 km Time Indication: 0 Date: 2015.12.13 Time: 08:47:50 ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0705 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: 6ADD93E88D0C3C6ED5-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 D HW: 5N0 035 342 D Component: SG EXT.PLAYER H13 0150 Revision: A1001003 Serial number: 7669254071 Coding: 010000 Shop #: WSC 01324 020 00200 VCID: 2859A9E05B80CE7E03-807C No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 C Component: RNS-MID H50 5274 Revision: AB001001 Serial number: VWZ6Z7L8017116 Coding: 04000442040000802009 Shop #: WSC 01324 020 00200 VCID: 377B7A9C863E51869A-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V12 8195 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 50 Reset counter: 245 Mileage: 186747 km Time Indication: 0 Date: 2015.12.04 Time: 00:47:13 ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 3AA 907 566 C HW: 4G0 907 566 Component: J769 SWA MasterH02 0010 Revision: 00H02000 Serial number: 6PZ 010 316-09 Coding: 0010174 Shop #: WSC 05311 000 00000 VCID: 397F7CA4702A47F66C-806C Subsystem 1 - Part No: 3AA 907 568 C Component: J0770_SWA_Slave_H02 0010 Subsystem 2 - Serial number: 6PZ 010 316-29 Subsystem 3 - Serial number: 5F12.09.1300H02000AMS15048ÿ Subsystem 4 - Serial number: S15048ÿ 2 Faults Found: 02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 205 Mileage: 188517 km Time Indication: 0 Date: 2013.01.01 Time: 00:00:00 02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 205 Mileage: 188517 km Time Indication: 0 Date: 2013.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA Component: Tuer-SG 009 2121 Coding: 0004279 Shop #: WSC 01324 020 00200 VCID: 76E5B79801B4E88E41-8022 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 5N1-909-144.clb Part No SW: 5N1 909 144 L HW: 5N1 909 148 G Component: J500__APA-BS KL.310 1401 Revision: 1AH03729 Serial number: 00110080167401 Coding: 0000258 Shop #: WSC 01324 020 00200 VCID: 3B7366AC7A1675E67E-806E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AN Component: EZE_2 H56 1642 Revision: H56 Serial number: 211013F1000993 Coding: 050B0100 Shop #: WSC 01324 020 00200 VCID: 6FEB82FCBEEED94682-803A Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J245EE20SKB13 H02 0220 Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591 Component: J394EE20SKB13 H02 0220 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 1T0 959 702 S HW: 1T0 959 702 S Component: Tuer-SG 009 2121 Coding: 0004535 Shop #: WSC 01324 020 00200 VCID: 489909603BC02E7EE3-801C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb Part No SW: 5M0 907 357 E HW: 7L6 907 357 C Component: AFS-ECU H04 0080 Revision: -------- Serial number: -------------- Coding: 030200000F000200 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_HeadlRegulVWAFSPt 002006 ROD: EV_HeadlRegulVWAFSPt_SE36.rod VCID: 366577988934A88E81-8062 Left_headlamp_power_output_stage: Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB Component: LeiMo links H06 0002 Coding: 320000 Right_headlamp_power_output_stage: Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB Component: LeiMo rechts H06 0002 Coding: 320000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 C Component: RNS-MID H50 5274 Revision: AB001001 Serial number: VWZ6Z7L8017116 Coding: 04000442040000802009 Shop #: WSC 01324 020 00200 VCID: 377B7A9C863E51869A-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V12 8195 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 51 Reset counter: 245 Mileage: 186747 km Time Indication: 0 Date: 2015.12.04 Time: 00:47:13 ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 7N0 907 534 HW: 7N0 907 530 AN Component: Batt.regelung H56 1642 Serial number: 211013F1000993 Coding: E100085A Shop #: WSC 01324 020 00200 VCID: 71EF8484A8DACFB694-8024 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 5K0 959 703 A HW: 5K0 959 703 A Component: Tuer-SG 007 2104 Coding: 0000144 Shop #: WSC 01324 020 1012552 VCID: 326D4B88AD5CB4AEAD-8066 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 D HW: 3AA 907 273 D Component: RDKBERU30 H09 0010 Serial number: 10000000124443 ASAM Dataset: EV_RDKBERU30 003012 ROD: EV_RDKBERU30_VW36.rod VCID: 356770949432A39688-8060 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H09 0100 Revision: 3A001001 Serial number: 00000140399288 Coding: 010D000100000000 Shop #: WSC 01324 020 00200 VCID: 30694180635086BEDB-8064 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 5K0 959 704 A HW: 5K0 959 704 A Component: Tuer-SG 007 2104 Coding: 0000144 Shop #: WSC 01324 020 1012552 VCID: 33634E8C5246BDA6A6-8066 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 7P6-035-730.clb Part No SW: 5K0 035 730 B HW: 5K0 035 730 B Component: TELEFON H09 1020 Revision: 1B001001 Serial number: 00007669235097 Coding: 0A01000000010101 Shop #: WSC 01324 020 00200 ASAM Dataset: UHVNA A01009 ROD: UHVNA.rod VCID: 2441BDD02FA82A1E2F-8070 No fault code found. ------------------------------------------------------------------------------- Address A5: Frt Sens. Drv. Assist (R242) Labels: 3AA-980-654.clb Part No SW: 3AA 980 654 D HW: 3AA 980 654 A Component: MFK_Gen1 H08 0300 Serial number: 0185622448 Coding: 010102000102020D0200040001010000 Shop #: WSC 01324 020 00200 ASAM Dataset: EV_47X 001639 ROD: EV_47X.rod VCID: 397F7CA4B82A47F66C-806C 1 Fault Found: 5570560 - Windscreen Heater for Front Sensors B11CE 15 [009] - Open or Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 202 Mileage: 188343 km Date: 2015.12.13 Time: 10:38:25 End-------------------------(Elapsed Time: 03:59)-------------------------- Последний раз редактировалось jmb123; 19.03.2017 в 16:06. |
14.12.2015, 12:59 | #459 | ||||
P.S.: I noticed you have Side Assist, did you manage to make it work on your tacho? |
14.12.2015, 13:16 | #460 | ||||
I'm really thinking that my Problem now is the ECU Unit... maybe the ECU unit not supports ACC... Because he Try it first am he see this error (post #69) http://www.audizine.com/forum/showth...=1#post7340945 That means that ECU UNIT Want to see the ACC UNIT, but the Radar Unit it's not connected... And I never have this Error... only this like the another Guy 1 Fault Found: 4332 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [167] - - And maybe there is my Problem... I needed to try this on a Passat B7, but I don't have one.... |
