Старый 14.12.2015, 13:35   #461
Das Auto - Skoda YETI 1.8 TSI 6M 4x4
Сообщение от jmb123 Посмотреть сообщение
... And I never have this Error... only this like the another Guy
1 Fault Found:
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
And maybe there is my Problem... I needed to try this on a Passat B7, but I don't have one....
I also think that you are right, your ECU doesn't fully support ACC! What do you mean you must try on Passat B7?
judasfan вне форума   Ответить с цитированием
Старый 14.12.2015, 13:50   #462
Das Auto - VW Touran
Сообщение от judasfan Посмотреть сообщение
I need to try on a passat B7 to active the ACC without any ACC parts to know whats happends on ECU UNIT... If give me a error because the ACC Radar not found (like this Guy):
If my ECU Unit not supports ACC its F*cking difficult, but still possible...
jmb123 вне форума   Ответить с цитированием
judasfan (14.12.2015)
Старый 14.12.2015, 14:14   #463
I understood you! I bought VW Passat ECU with ACC support for CDAA engine like mine, but unfortunately my car is 4x4, and I was told that the ECU I bought is from front wheel drive. I don't have time to check this, but if someone can extract the ACC part from ECU memory.........
Старый 14.12.2015, 16:14   #464
@jmb123
My friend, I think you should start looking at VW Passat ECUs! Engine code CFGB looks promising and is coupled with DSG. You should compare schematics to see if there are some major differences, if no, I think you can swap the ECUs.
Последний раз редактировалось judasfan; 14.12.2015 в 16:19.
Старый 14.12.2015, 17:52   #465
Das Auto - vw golf vi gtd 2010
I don't have time to check this, but if someone can extract the ACC part from ECU memory.........[/QUOTE]
hi
I have everything flash files for the engine ECU (golf Passat Touran Tiguan)
** * .frf
I can send the file to the mail
Could anyone for golf modify software to support the ACC?
Последний раз редактировалось tomino55555; 14.12.2015 в 17:58.
tomino55555 вне форума   Ответить с цитированием
Старый 14.12.2015, 19:25   #466
But Tominino55555 the Risk ist to Big to fail! I don't like the risk and I prefer to do this with some Chip Tuner. The Problem it's here in Switzerland I don't have to many choices, and they don't do this things.
The files have I too, but... I don't know... I need to show.
Knows everyone if I coded a new Engine ECU if its possible to put it the old again. I mean if both are working or just the new one??
Старый 14.12.2015, 19:50   #467
If I understood you correctly, if you adapt new one, both ECUs will be usable in your car! It's like the cluster, you can use your old. Immobilizer and mileage information is stored in the ECU and the cluster on PQ35 platform cars. Tools like ABRITES can do the swapping.
Старый 14.12.2015, 19:57   #468
Thanks for answering!
I'm Thinking to bought a second one (ECU Unit) and coded it too my car. If I have both working than I can try another Software.
But first I'll watching with some Tuners.
Старый 14.12.2015, 23:05   #469
Аватар для mexanicka
Das Auto - Golf 6 GTI
Guys, I'd like warning you that modern ECU has integrated immo that have comply immo in tacho. Normally you have to makes marriage through VW server. Otherwise engine will be blocked.
And one of the most important is Power Class of engine ECU that MUST be the same as in your original taho immo. One polish guy Marcin plays with power class in ECU and at the end has ECU "brick" all cases different from original value.
Последний раз редактировалось mexanicka; 14.12.2015 в 23:10.
Старый 14.12.2015, 23:24   #470
Аватар для y-u-r-a
mexanicka, Коля я думаю можно поиграться с блоками, да и абрикос в помощь
Автомеханик
judasfan (15.12.2015)
Старый 15.12.2015, 00:26   #471
Парни, а мы здесь много что написали, а результат пока не очень...А я думаю, есть знатоки, специалисты, которые за деньги смогут сделать активацию в наши моторники....если кто-то знает такого человека, можем попробовать связаться....а если имеет надежда, то думаю мы вместе сможем собрат деньги, чтобы заплатит этого специалиста!
And now for our English speaking friend, translation of the above statement:
Guys, we wrote a lot in this thread, but without any visible result! I think that there are people, specialists, who will do the job of activation ACC in our ECUs for money! We can try to find such people, and if there is hope, we can all collect money and pay for results!
jmb123 (15.12.2015)
Старый 15.12.2015, 01:10   #472
Здесь я думаю простым "тыком" не обойтись.
Нужно иное понимание предмета. Равно как те, кто не знаком с параметризацией освещения, им не понять, как можно по-другому закодировать свет с помощью "Васи" или я так и остался в неведении, как мне закодировали новую антенну RKDS, а ведь тоже не простой адаптацией как для б/у.
Так и с активацией АСС в моторнике - нужен другой подход, доступ к каналам параметризации, если это так можно назвать. Все остальное - толчея воды в ступе.
Либо как со светом - входом в каналы параметризации и их настройкой, либо как с RKDS - заливкой карты параметров одним подготовленым файлом
Старый 15.12.2015, 09:52   #473
Сообщение от mexanicka Посмотреть сообщение
Привет mexanicka, это все верно что ты сказал! Но ничего нам не мешает питаться найти специалиста. Мои технические возможности в этом дело ограничены и честно говоря предпочитаю заплатить за услуга, чем ждать какое то чудо! Думаю, что есть и другие коллеги, которые на это мнение, поэтому написал верхний пост. Я не перестал искать такого человека, пока без успеха
Чтобы не говорит пустые слова, я скажу что у меня есть моторник с VW Passat, у которого есть ACC и я готов отдать этот моторник подходящего человека.
Последний раз редактировалось judasfan; 15.12.2015 в 09:59.
Старый 15.12.2015, 12:10   #474
I would do this! But finde someone who can do this it's dificult too...
I found yesterday another Guy who wants have ACC too on a Golf VI
His project: http://forum.golf6.pl/vw-mk6-profil/...html?hilit=ACC
And some discussion about ACC: http://forum.golf6.pl/post30482.html?hilit=ACC#p30482
Старый 15.12.2015, 23:28   #475
@jmb123
I contacted several tunings companies, but so far with no luck!
There are some very clever guys in Russia, don't want to offend anybody, but without material interest they will not "move their finger"!
Последний раз редактировалось judasfan; 15.12.2015 в 23:51.
Старый 09.03.2016, 14:58   #476
Аватар для Perikov
Ребята, почему тема заглохла? Никто не добился результата? Я так понял вопрос оставался только в блоке мотора? И я как-то потерял нить - с лидаром (тем что над зеркалом на лобовом стекле) никто не стал связываться?
Старый 09.03.2016, 21:58   #477
Аватар для y-u-r-a
Perikov, Я занимался лидаром, но этот проект просто заглох из-за дороговизны лидара, и найти его практически нет возможности рабочим, его прекрасно заменяет радар от пассат Б7 и ставиться очень легко. Пока что камень преткновения это моторник, если активировать есть возможность, то тогда все решаемо, скоро кстати первый кадди будет с адаптивом...
Автомеханик
Старый 09.03.2016, 22:36   #478
Perikov.....скоро кстати первый кадди будет с адаптивом...
Привет Юра, у тебя кажется есть информация, пожалуйста, поделись с аудитории!
y-u-r-a (09.03.2016)
Старый 09.03.2016, 22:43   #479
Аватар для y-u-r-a
Привет Данаил. А чем делиться, просто не чем... У человека кадди и моторник принимает кодировку АСС, а дальше просто поставить радар и закодировать...
Автомеханик
judasfan (09.03.2016)
Старый 09.03.2016, 22:57   #480
А какой у человека блок АБС?
Текущее время: 20:07. Часовой пояс GMT +3.
