Старый 29.12.2018, 09:31   #2061
Das Auto - Golf 6 1.4 tsi 122 CAXA
Смех
Сообщение от Малышев Посмотреть сообщение
Через 70-80 тыс -для самоуспокоения. На 49тыс(если реальный) никакого треска в цепи и натяжителе быть не может.Просто нашему двигателю свойственно шумновато работать после запуска 2-3 мин.
Ну а в сервисе,тем более ОД-Вас конечно там ждут с 35тыс руб(в лучшем случае).
я сказал 3 секунды, не 3 минуты , и это не шум двигателя... это шум или цепи или натяжителя или фиг знает.. Слышно только после ночи и только в холодную погоду (от +3 и ниже).
п.с. ОД за замену цепи берут 100к в лучшем случае.
Johnydriver вне форума   Ответить с цитированием
Старый 29.12.2018, 11:19   #2062
Аватар для linguarex
Das Auto - Touareg R-Line
Сообщение от TSI inside Посмотреть сообщение
Hi guys, Merry Christmas first of all
I hope some of you could help me. Sorry that I'm writing here in English. I was reading this forum by using translator since all I speak in Russian is only the bad words..
I own golf mk6 1.4 TSI (engine code caxa). Odometer today shows ~132k km, according to vw center chain was replaced at 80-90k km (I don't remember correctly). And when it's cold outside the starting is with some strange sounds. There's a link with the startup sound https://1drv.ms/u/s!AuQ4x4CMShFtiI8XXPD37YVF4UJZNQ;Does that sound like a problem for you guys? Or it's just me being paranoid?
I also have vcds 12.12 at the hand and I managed to get reading from 213 group (I found info about that in this thread):
That says steering angle though it doesn't change when steering the wheel. Is that a correct measurement?
I'd be grateful if someone would take a look at this. Since there are no useful info about this in other forums. Cheers!
Hi comrade!
You've got sound of sagging chain, but it's not critical at all. 1-5 seconds on the cold start is ok. There is an oil chain tensioner on CAXA, and it needs time for oil to pump the tensioner on the cold start.
Angle in 213 group could be not informative, because default position from the factory is 0 and when chain is sagging it comes to negative values up to -4 which is critical. After first chain replacement at 80-90k km, your default position could have been changed. Better to watch it right after replacement to know from what new default value count 4 degrees.
From my point of view, you could calm. Just watch rarely 213 group (try to count to -2.5 -3 degrees) and check the duration of clanging sound on the start until odometer will show you 180-200 k km or you receive check engine.
Hope I helped you a little
Merry Christmas and Happy New Year!!!
linguarex вне форума   Ответить с цитированием
TSI inside (29.12.2018)
Старый 29.12.2018, 13:37   #2063
Thanks for response, chigi!
There are no errors for the engine. I change oil every 10k km and I always use parking brake. :D
It's my first petrol yet first driven by the chain so after reading some info on the web and watching some videos I became nervous about that.
Less read -> More drive
---------- Сообщение добавлено в 13:43 ----------
Кстати, по цепи: менял недавно цепь в ВАГ С на Волгоградке. Они мне звонят и говорят, что было реализовано некое шаманство со старым натяжителем, чтобы цепь не звенела. Машина до этого обслуживалась у ОД и они крышечку открывали для проверки. Шаманство заключалось в установке кольца на шток натяжителя, чтобы цепь была преднатянута... Натяжитель вместе со всеми прочими зч, исключая шестерёнки и фазорегулятор, был заменён.
пробег при замене цепи был 170 000 км, цепь - первая
Старый 29.12.2018, 13:59   #2064
Аватар для TSI inside
Das Auto - VW GOLF MK6 1.4 TSI, CAXA, 6MT, 2009
Thanks guys!
linguarex you made a good point, since I don't know the value which was when the chain was changed, but now I do have some reference value for checking this.
I use 5w40 oil and that sound is only when cold. During the warm season of the year I haven't noticed anything like that. I don't think it's oil fault either. It's just physics, that oil leaves the tensioner.
Golf VI 1.4 TSI Highline |
TSI inside вне форума   Ответить с цитированием
Старый 29.12.2018, 16:18   #2065
Аватар для Кукиш
Сообщение от sad1002 Посмотреть сообщение
А подробнее можно? что за кольцо, куда надели, вы ничего не путаете? Мотор точно САХА?
Старый 14.01.2019, 14:15   #2066
Das Auto - Golf CAXA 2011
менял недавно цепь в ВАГ С на Волгоградке. Они мне звонят и говорят, что было реализовано некое шаманство со старым натяжителем, чтобы цепь не звенела. Машина до этого обслуживалась у ОД и они крышечку открывали для проверки. Шаманство заключалось в установке кольца на шток натяжителя, чтобы цепь была преднатянута... Натяжитель вместе со всеми прочими зч, исключая шестерёнки и фазорегулятор, был заменён. пробег при замене цепи был 170 000 км, цепь - первая
Шаманят там конечно знатно))) О какой крышечке речь?
Для кольца канавку на штоке точить надо, не думаю что оффам это под силу, а мотор точно САХА?
Старый 02.02.2019, 18:27   #2067
Скорее из поршня старого натяжителя срезают кольцо ок 10 мм и вставляют в новый. Чтобы поршень до конца не утапливался.
http://vwts.ru/forum_txt/index.php/t238920.html
Последний раз редактировалось and315; 02.02.2019 в 18:34.
Старый 16.02.2019, 12:47   #2068
Das Auto - Golf 6
Здравствуйте, задумался установить этот самый ремкомплект 03C 198 229 C, пробег 130 тысяч, чеков нет, странный звук сначала есть пару секунд, минуты две тишина, потом тарахтун какой-то до прогрева масла до рабочей температуры. Тарахтун слышен больше от колеса нежели чем из моторного отсека, странно, может вообще это опора двигателя или какой-то элемент защиты об картер колбасит. Но цепь все равно менять скоро придётся. Прочитал кучу инфы и не нашёл единого мнения о сервисе, где смогут грамотно поставить ремкомплект 03C 198 229 C, разве что suslikrus, я ему написал, пока молчит, но вроде там ценник космический. Не подскажете, где в Москве, Калуге или Туле можно найти грамотного специалиста к которому не придётся 5 раз возвращаться с чеком?
alex_MORPH вне форума   Ответить с цитированием
Старый 16.02.2019, 18:13   #2069
Аватар для Кукиш
Господа, повторяю в стопитцотый раз, ЗВУК мотора при первых минутах, не говорит о неисправности мотора, он говорит о том что из мотора стекло масло, и пока система полностью не наполнится, звук не станет лучше. А наполнятся там есть чему. Цепь нет смысла менять раньше чем загорится ошибка "00022 P0016: Ряд 1, датчик положения распредвала -G40/датчик положения коленвала -G28, несоответствие сигналов." Именно эта ошибка говорит о том что цепь растянулась, и распредвал не проходит по фазам к коленвалу. Самое главное ПОЛЬЗУЙТЕСЬ РУЧНИКОМ, ВСЕГДА!!!! Никогда не оставляйте машину на передаче.
Сообщение от and315 Посмотреть сообщение
Очень мудрое и не дорогое решение! Буду делать так при замене. Комментаторы там как всегда блещут! Прям с самого первого.
Старый 16.02.2019, 19:11   #2070
Das Auto - Golf 6
Всю голову уже с этой цепью сломал. Suslikrus ответил - с запчастями 35 тысяч получается. Не очень бюджетно. Вот что мешало ВАГу сделать смотровое окошко для оценки состояния натяжителя?
Последний раз редактировалось alex_MORPH; 16.02.2019 в 19:18.
Старый 16.02.2019, 19:24   #2071
Аватар для Кукиш
Суслик очень жесток.
Старый 18.02.2019, 08:15   #2072
alex_MORPH, там где бюджетно зачастую не понимают что надо делать, ну и не забывайте, что скупой платит дважды, а жадный трижды)
Старый 18.02.2019, 15:13   #2073
Das Auto - шкода 1,4 саха 2009
А Суслик стабилен - за 4 года ценник не поменялся.
из минусов только ценник, из + - он не только грамотно, быстро (на все 3 часа), с однозначно не поддельными запчастями, но и надежно это все сделает + ответит на все вопросы и посмотрит все в округе на предмет других косяков. Но каждый решает сам как тратить деньги...
willin вне форума   Ответить с цитированием
Goblin (11.06.2019)
Старый 18.02.2019, 19:38   #2074
Аватар для Кукиш
Менять цепь не долго. Для замены нужен набор спец инструмента, без него ну никак. Соответственно случайные люди отсеиваются. Сложного там ничего нет, тупо выполнить скрипт из ЭЛЬЗЫ, с небольшими отступлениями. Не нужно делать из людей богов. По мне так Суслик обычный такой слесарюга, который словил звезду, и на этом делает бабки. Молодец, но мне он не интересен и не авторитет.
vw-76 (18.02.2019)
Старый 18.02.2019, 19:50   #2075
Das Auto - golf
200 тык. вывалило ошибку по распредвалу за пределами регулирования.
поменяли саму цепь, башмак натяжителя, успокоитель, натяжитель (можно было не менять) прокладка передней крышки это по ваг, сальник тефлоновый коленвала в.рейнц, герметик тоже в.рейнц оригинал, работы часа на 2-3.
ес-но масло фильтр и масло
еще поменяли колпачек тнвд (был протерт насквозь)
и нужен шаблон для фиксирования распредвалов (в инете чертеж есть) микрометр (стойка токарная и спица от велосипеда) это из спец инструмента
Последний раз редактировалось vw-76; 18.02.2019 в 19:53.
Старый 18.02.2019, 20:21   #2076
Аватар для chigi
Das Auto - AUDI
Некотрые «мастера» ТО без косяков провести не могут, например. Да и сколько тут людей отписывалось, что после замены ГРМ появлялись чеки и т.д. Суслик просто с прямыми руками, вот и все. А менять у него или нет - выбор каждого
Старый 18.02.2019, 20:45   #2077
Das Auto - golf
Сообщение от willin Посмотреть сообщение
а вот это сейчас лишнее, а то потом приезжают с такой кашей в голове, еще и рассказывают как делать и по чем, в инете видел, там сказали и пр.
а спрашиваешь че не сделал сам до сих пор и .............
Старый 19.02.2019, 08:33   #2078
vw-76, а ещё каша в голове у некоторых "мастеров", мне например, пытались доказать что при замене комплектом звезду на к/в снимать и менять не надо, мол и так всё будет работать... При этом ценник озвучивали точь в точь как у Суслика...
Старый 19.02.2019, 11:08   #2079
vw-76 - а Вы считаете что чем меньше клиент знает, то Вам проще? чего нибудь не сделать.... или сделать не так как надо....Боитесь что с Вас спросят больше, чем Вы хотите/может предложить? Без суслика и иже с ним так бы все и бегали по официалам и лапшу бы носили из сервиса в сервис.
Лично я ему благодарен, за то что он пытается донести до аудитории тонкости и особенности, при чем не только для клиентов но и для "мастеров ".
sk_npzao (19.02.2019)
Старый 19.02.2019, 11:19   #2080
Аватар для chigi
Das Auto - AUDI
Точно, так бы меняли все только цепь с натяжителем и продолжали трещать...
Текущее время: 22:59. Часовой пояс GMT +3.
